is it possible to use the Pixhawk PMW Signal to dimm an external LED
I got an LED-driver with an PMW input but if i try it the led is only flickering.
Yes, the Pixhawk can control an LED with a PWM input (like our very own), but there are some parameters that need to be known:
What PWM frequency does the LED driver require?
What duty cycle does the LED driver require?
-Jacob
Hi Jacob,
This is the led-driver what im going to use https://pcb-components.de/led-abwaertswandler-buck-step-down/black-power-v3-2800ma-3000ma-5-5v-50v-detail.html
I have exactly the same issue as this old post. Have built my own light but when connected (output7) it stays vaguely lit. Obviously the PWM is different range. I don’t need dimming just simple on-off. Any easy way I can achieve that with QGC 4.0.8 (or any other version) the driver info is:
Technical Data PWM input: Max. input voltage: 28V Logic level high : min.2.8V Logic level low : max.0.6V Recommended PWM frequenzy : 150Hz-2000Hz
I cheat. I just mechanically connect a servo to the pot of a pwm dimmer control.
Thanks Darrell,
I am at sea atm and no possibility to go that route. Read every post there is on the topic but unable to find a solution. Was hoping Jacob could point me in the right direction, right now I am diving with the light attached but not connected.
J
Hi Willian,
I thought i needed a physical reley for that. Don’t know i missed that. I only need on off. Thanks a ton, will try it right away.
Best
You don’t need a physical relay, it will output either 0 V or (IIRC) 3.3 V on the pin, I guess that will work fine for your setup in “normal mode”.
