Ping360 power inductor replacement
We noticed that one of the power inductors came loose after opening up the Ping360 to change modes. Upon further inspection, we saw that one of the legs had broken off. We are planning to remove this broken one entirely and solder on a new one. Does anyone have any information on this part, such as manufacturer and the company that sells it? Thank you!
Hi @RT-2010, welcome to the forum :slight_smile:
The Ping360 hardware is not open source (so I can’t point you to a public schematic or similar), and I don’t believe we source the components for it directly.
A 101 marking on an inductor (as in your photo) indicates a rated inductance of 100µH, though unfortunately I’m unsure of its other characteristics. If the details you need aren’t clear from the markings on the part I’d recommend reporting a product problem in case our support team is able to provide more information or an alternative solution.
