During the dive, the Ping1D sonar may disconnect.
If I restart the PingViewer application, it does not find the connection to the sounder.
Is there a way to reconnect the sounder during the dive, without relaunching the PingViewer application, and without lifting the rov to the surface to turn it off and on again?
I have an example of a log file of a dive where it happened, if that helps …
Can you please share the log ?
Also, can you check the system page and make sure that there is no under-voltage warning ?
It could be possible to be the usb connection or any wiring that may affect the power for ping1d or disconnection ?
