Hi everyone,
Ping sonar not working when it is connected as UDP, but working fine when it connected directly through USB port
Just to make sure, are you talking about Ping360 right ?
Make sure to follow the instructions here: https://bluerobotics.com/learn/changing-communications-interface-on-the-ping360/
To test, make sure to connect Ping360 in a router and make sure that your computer is connected in the same network via wifi or ethernet.
No patrick , i am talking about ping 1D, not ping 360.
First, are you running the last version of companion ? Make sure to update your companion computer to the last version available.
Hi Patrick,
i have updated the companion to latest version.
Did you reboot ?
Is there a pingproxy service running ? You can check that in service page.
