Ping 1D UART connection
Hi
can i connect Ping Altimeter directly to telemetry 1 or 2 ports of pixhawk since its communication protocol is UART and also i can see range finder option in SERIAL1 /2 parameter ?
thank you
It should work fine. You won’t be able to connect to it via PingViewer, though.
Thanks for your reply willian. is This working for me.
But my question is , there was an option for Gain adjustment in ping viewer .in case of UART connection, will it be the gain in Auto mode ?
Also need to know about the rangefinder orientation if i am using to get the distance from a wall in front of ROV?
thank you
