I’m noodling again on a design for an autonomous surface vehicle. I’m planning to using the Blue Robotics Thruster as the propulsion. I’ve not decided yet between T-100 and T-200. The hull design is more like a catamaran with the thrusters mounted under the pontoon, two thrusters, one on each side.
I’m looking for images or information related to the cable coming out of the thruster. I wasn’t seeing it in the documentation.
Where does the cable exit the thruster?
What is cable diameter?
I though I read that the Blue Robotics mounting bracket has a hole of the cable to pass through, but I didn’t see that in the image I looked at.
