I was wondering if anyone has used a Raspberry Pi 5 with the navigator. If so, does everything, including the heat sink, fit properly, and are there any issues I should be aware of?
Thanks.
Thanks.
Hi @Angus.F -
Weâve only just received some units, and are beginning to investigate what it will take to update BlueOS for Pi 5 compatibility. Currently it is not supported!
I have the Navigator and a Pi5 and it works well so far with the BlueOS. I am only at the development stage so some way to go to integrate it.
The heatsink fits very well and the navigator is held with 2 screws on the diagonal. All nice and secure.
My only issue is in trying to build the firmware under Windows with WSL and Ubuntu. It builds without error but the binary doesnât run when uploaded to the PI5 and I suspect this is a compiler issue but so far have found no information in how to install the correct compiler.
If you are running into glibc issues, I recommend using gcc 10.2.
Iâm using this one (sharing because I was told it has been hard to find lately):
gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf.tar.xz
Hello, may I ask how you managed to get this to work? When I try to flash BlueOS on my RPI 5, I get an error message: "Device-tree file âbcm2712-rpi-5-b.dtb not foundâ. Is there a way around it? I am quite new to this. Thanks a lot.
I installed this and it gives the following error when I try to select it as the toochain.
dave@HUEY:~/ardupilot$ ./waf configure --board=navigator --toolchain=/opt/gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf
Setting top to : /home/dave/ardupilot
Setting out to : /home/dave/ardupilot/build
Autoconfiguration : enabled
Checking for program 'python' : /usr/bin/python3
Checking for python version >= 3.6.9 : 3.10.6
Setting board to : navigator
Using toolchain : /opt/gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf
Could not find the program ['/opt/gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf-ar']
(complete log in /home/dave/ardupilot/build/config.log)
I then get this error when I try to build with ./waf sub
../../libraries/AP_HAL_Linux/Thread.cpp: In member function âbool Linux::Thread::set_stack_size(size_t)â:
../../libraries/AP_HAL_Linux/Thread.cpp:248:44: error: âPTHREAD_STACK_MINâ was not declared in this scope
_stack_size = MAX(stack_size, (size_t) PTHREAD_STACK_MIN);
I am assuming the toolchain dir structure looks like this:
ls /opt/gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf/
10.2-2020.11-x86_64-arm-none-linux-gnueabihf-manifest.txt arm-none-linux-gnueabihf bin include lib lib64 libexec share
If so, the toolchain option should include bin in the path, and name the toolchain:
--toolchain=/opt/gcc-arm-10.2-2020.11-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf
Hi, are there any BlueOs updates for pi5 with navigator?
In looking into this we found that the Raspberry Pi 5 hardware architecture is a reasonably substantial departure from that used by the previous boards, because the GPIO pins have changed from being handled by the main application processor chip to the peripheral controller chip, which changes how theyâre laid out in memory as well as which interfaces are available.
There is an open GitHub issue about adding support for the RPi5 to ArduPilotâs hardware abstraction layer (HAL), which will be the best place to track any updates.
If Iâm remembering correctly from our internal discussions:
*_RPI.* files written[1] to handle the new board (or at least significant changes to the existing files, to describe the new memory mappings)in the AP_HAL_Linux library âŠď¸
"the Raspberry Pi 4 22/23 pins, used with I2C6, appears incompatible with the Raspberry Pi 5, where the 22/23 pins only provide as alternative function I2C3 that conflicts with 6/7 pins that only provide I2C3 as well.
If we can configure the hardware allowing to connect both 6-22 (SDA) and 7-23 (SCL) , sharing the same I2C3, it may be possible to have the navigator running without losing the I2C connectors. But that may affect our PWM control, since itâll share the same bus." - patrickelectric âŠď¸
Canât we run it using Docker. Everything is possible with docker, I need to catch up for an urgent project and unfortunately I donât have time to code from the beginning and I donât have the experience to understand the problem, but when I look at the docker logs, I see that the memory limit of bazo py files is 0.
Hi all, Iâm working on bookworm and pi5 support on this PR.
The artifact built by CI works, but there are a couple of things to fix still
Hello everyone. Could you please provide any updates on the release date of Raspberry Pi OS Bookworm? The Pi 4âs performance is insufficient for AI vision tasks, but the combination of the Pi 5 and a TPU are processing substantial amounts of video data. In todayâs world, where there is a desperate need for relatively affordable CV systems, the Navigator and Pi 5 could become one of the most sought-after systems.
Weâre still working on Pi 5 support, but donât have a fixed release date for it.
The current hope is to complete it this month, but it might end up being next quarter (depending on our other development priorities).
Glad that youâre excited about the potential! ![]()
Any update for installing blueOS on Pi 5
Hi @Synsm22, welcome to the forum ![]()
RPi 5 support is currently planned for completion some time this quarter. The latest updates in Willianâs (draft) pull request were on 13/June.
Hi Eliot,
Is there any updates about RP5 support?
Hi Folks,
I see the PR has been merged.
Does that mean the navigator (with latest firmware) will work with Pi5.
Will there be any upcoming changes to the navigator design? (besides something like heatsink shape)
We need a new spare navigator, but holding off for Pi5 compatibility.
Hi @XYZEng -
The Navigator is never flashed with any âfirmwareâ - it is simply accessed by whatever autopilot version is running within the Docker container provided by BlueOS.
A revision to the Navigator hardware proved necessary to work with the Pi 5, in addition to the heatsink update. This moved the magnetometer to not interfere with the heat-sink fan, along with other minor changes.
Hi to all,
So if understand correctly a new Navigator revision is planned
Do you have any estimate date for when will be available?
I have too a plan to use a Rpi5 (Rpi4 performance for my AI vision project is too limited) with Navigator waiting
Meanwhile i read that latest blueos beta boot on Pi5
What are the caveats still present in this configuration, if any?
Thank you
