Hello. About 2 weeks ago we received and set up our BlueRov2 with Heavy Config Kit.
Today, we started the installation of some custom sensors. To communicate with our sensor, we are using serial communication. We used a USB to RS232 (TX/RX) adapter (where the USB is plugged into the pi). While debugging some connectivity issues in the adapter/cables, the raspberry pi / navigator suddenly stopped working. On startup, the thrusters are powered on, but there is no beep for the flight controller and the pi is not lighting up. Naturally, we cannot connect to blueos.local or QGC
There is power coming into the system from the battery and into the power blocks, but there seems to be no power coming out of the 5/6V BEC. We are unsure if its the BEC that’s dead, or if our pi/navigator is fried.
When we debugged, we simply unplugged the battery, swapped TX/RX in the adapter, and plugged the battery in again. After this, we havent been able to power the raspberry pi. It seems unlikely that swapping RX/TX is able to fry everything.
Does anyone know if it’s just the BEC that’s fried or if our pi/navigator is affected? How can we potentially debug/investigate, and what could the cause be?
