We are building an AUV where depth holding is very important.
I can perfectly go into DEPTH HOLD mode with PYMAVLINK → Python 3.6.
But the rover comes around 1 meter above and then again goes down. As Jacob said they are still working on it.
So, I thought to go into STABILIZE mode, read the depth every 1-second and throttle downward with python code. It’s like depth holding from the python code.
import time
from pymavlink import mavutil
import arduSub_pymavlink_methods as pixhawk
# Create the connection
# Need to provide the serial port and baudrate
master = mavutil.mavlink_connection(
'COM5',
baud=115200)
# Wait a heartbeat before sending commands
master.wait_heartbeat()
time.sleep(2)
# ARM the Ardusub
master.arducopter_arm()
# These are functions I wrote in another file and imported it to keep the code clean
pixhawk.change_mode(master, 'STABILIZE')
# Request SURFACE_DEPTH parameter
while True:
master.mav.param_request_read_send(
master.target_system, master.target_component,
b'SURFACE_DEPTH',
-1
time.sleep(1)
try:
message = master.recv_match(type='PARAM_VALUE', blocking=True).to_dict()
print(message['param_id'].decode("utf-8"), message['param_value'])
except Exception as e:
print(e)
exit(0)
How can I continuously get the depth of my AUV with 0.2m Precision?
The code above only returns -10 then I set on QGC.
Or suggest me a way to keep the AUV at a certain DEPTH. I don’t have any underwater GPS.
USING :
Pixhawk - PX4
Ardusub - 3.5.X (latest stable release)
Depth Sensor - Bar30
Platform - Windows10(For testing Purpose)
Python - 3.6
Library - Pymavlink
Frame Config - BLUE ROV2 (6 Motor)
