Hi everyone!
I am a student who is working with a BLUEROV2.
I recently developed a code to arm the vehicle and set it in “DEPTH HOLD” mode in QGC using the Pymavlink library.
I attach the code:
master = mavutil.mavlink_connection('udpin:0.0.0.0:14440') #Create connection if QGC open
boot_time = time.time()
master.wait_heartbeat()
if (not attitudeControl.is_armed(master)):
master.mav.command_long_send(1,master.target_component,mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM,0,1, 0, 0, 0, 0, 0, 0)
print("Waiting for the vehicle to arm")
master.motors_armed_wait()
print('Armed!')
master.set_mode('ALT_HOLD')
The problem is that when I run the code it returns “Unknown mode ALT_HOLD”.
So I was wondering if the “ALT_HOLD” parameter is deprecated (although this parameter is used in the example on Ardusub) and if now a new parameter like “DEPTH HOLD” is used as used in this example and as defined here.
If it can be useful for solving this problem, I’m using QGC v.4.2.3
