Number of Penetrator on BlueROV Heavy
How many penetrator can fit on the BlueROV Heavy end cap?
I need 20-22 connectors but it seems it won’t fit.
Thanks,
Best regards
Hi @dudu,
We sell a variety of different end-caps for our enclosures, but the 4" enclosure tube used for the BlueROV2 electronics comes with 18 M10-sized holes (which is the maximum we can fit in that size) so you won’t be able to install 20+ penetrators into it.
Depending on what you’re connecting, you may be able to combine some of the cables inside or outside the enclosure, using splices or by daisy-chaining some of your components.
