Not able to Pitch and Roll
Hi
I have a BR2 v2 with the heavy lift configuration with the latest software updated on everything.
QGC says it doesn’t support the shift function so I have set the pitch incl / decline and roll incl / decline on the controller buttons but still unable to pitch and roll the BR2.
Is there another setting I need check / uncheck. Originally I was using and xbox controller and followed all the windows game console tips. I am now using a ps4 controller.
Thanks in advance
I am having same issue - seems no way to assign values for “shifted” buttons
Look at JOYSTICK function - QGroundControl - Blue Robotics Community Forums
Hi @jwvanheest -
What joystick and button on it are you trying to map to shift? Sometimes the center button is not supported, as that post you shared details. It should be easy to map pitch/roll trim buttons to any button + shift button…
