Not able to communicate with gripper
Hi
I’m trying to connect a brand new Gripper, but I can’t seem to get any response from it. I’ve connected the power cables and tried switching from spare 3 to spare 2 to see if there’s a malfunction in the Pixhawk, but no response at all.
Any typical errors in connection?
Using Qground 3.2.4 topside.
Hi Tom,
Have you connected the wires as described in wiring connections ?
Are you running the last version of QGC (Rev6) and ardusub (3.5.3+) as described in QGroundControl setup ?
Thanks for the quick reply. Turned out I hadn’t updated the software, solved the issue with the latest version.
Tom
