Viewing this thread in 2022. Still having a similar problem - software set up instructions indicate that the current companion software version is 0.0.31 (as @ 3 Dec 2021: https://bluerobotics.com/learn/bluerov2-software-setup/). However I’m getting no button on the system check page to update from the 0.0.17 that’s on there at the moment. Further, none of the various links to zip files for sideloading onto the Raspberry Pi seem to work. Can anyone point me to either a) a fix on the system page or b) a link to a file that I can sideload in? Cheers
I believe 0.0.17 is old enough that the update process is broken (if I remember correctly there was a service we were using that stopped working), so you’ll need to follow the Installing Companion instructions from our docs, to download the latest image and flash it onto the Raspberry Pi’s SD card.
You might also be interested in checking out our Companion 1.0 Beta, which is the replacement software we’ll be building on going forwards
