NEW Rasbberry Pi cam module
Any one planning on putting this on their BluROV?
Having a higher-resolution sensor is nice, although it looks like the module itself is $50, with the lenses costing extra. Plus the lenses are manually operated.
I prefer a D1-resolution camcorder with 78x optical zoom, which more than makes up for the lack of megapixels, especially underwater. Available used on eBay for $50, usually. Search on eBay for ‘Panasonic SDR-T55’, or T70.
Hello, is the Fathom Tether’s bandwidth okay with this camera?
Hi @steneo23,
Please check my comment in your other post:
Hello Patrick,
So as i have a BlueROV2 with Raspberry Pi 3 and i want to use the new Pi Camera for making a slam or a visual odometry as an example. What is the thing to do to bypass or solve the issues?
Hi @steneo23,
Without decreasing the video resolution, the only way that I can imagine is tu use a Raspberry Pi 4 or anything that can handle the bandwidth necessary for the video stream.
We don’t officially support boards that are not the Pi 3B, but we are working on it.
Thank you @patrickelectric :slight_smile:
We are using the Pi 3B and we will come up if we find any solutions.
Hi Patrick,
I’m also interested in the new Raspy HD camera…
I tried to directly connect on a Pi 3B but QGroundControl said “no Video”…
So, can I try to install ArduSub companion on a Pi 4?
Companion can be installed on a vanilla raspbian image like this:
wget https://raw.githubusercontent.com/jaxxzer/companion/setup-clean/scripts/install.sh
chmod +x install.sh
./install.sh
This is working on pi 3 and pi 4.
Could be considered stable?
I would like to have a better camera on our towed system.
Recently I saw a project where it was implemented a 4K camera in a ROV. Here is the link Ocean Secrets ROV proyect
