Navigator SBUS connection problem
Hi @andrewjamez -
You should NOT need to bridge that pad for SBUS to function! Here are the recommended steps:
  1. Flash Rover Beta (>=4.4) (assuming you’re trying to use a RC transmitter with a Blue Boat?)
  2. Make sure there’s nothing connected to Serial1
  3. Set SERIAL1_PROTOCOL to RCIN
  4. set RC_OPTIONS to 36
  5. Restart the autopilot
You should then be able to calibrate and use your RC transmitter from QGround Control Vehicle Setup menu.
