Hi All.
I have a problem with my Bar02 sensor. It work perfectly with pro mini and normal arduino. But when i hook it up to MrkFox1200 the sensor is not detected.
Even I2C scanner does not detect the chip.
Any advice?
Hi All.
Any advice?
Can you give us a picture of how everything is connected?
Straight up connection…
Bar02 - Mksfox1200
+3.3V - VCC
GND - GND
SDA - SDA
SCL - SCL
Running your lib… Works like a charm on 3.3v 328p chip without any problems…
Tested with and without external pullups at 4k7 Ohm.
Does not have the hardware in front of me…
