Hello, I have a Bar30 sensor that I am using on a Nvidia Jetson Orin Nano Developer Kit. I have tried to use i2cdump to check if the sensor is being detected. I am not sure what to look for so I will post some of my outputs. Furthermore, I made a big assumption that it is being detected and used the library for the sensor. GitHub - bluerobotics/ms5837-python: A python module to interface with MS5837-30BA and MS5837-02BA waterproof pressure and temperature sensors.
I am trying to run the example.py file in order to see if I can read from the sensor but I get these errors can someone walk me through on where I should start the debugging process?
Hi @washedsteven, welcome to the forum ![]()
You haven’t provided information or a photo about how you’re connecting the sensor to your board, which makes it difficult to help you. I also unfortunately don’t have access to that board type, so can’t run my own tests of it myself.
A few questions:
- Do you know which I2C bus you’re connecting it to?
- According to this pinout pins 3/5 are for bus 7, and pins 27/28 are for bus 1
- Have you installed
smbus2?- It may be necessary to install through
pip, but I’m not sure
- Do you know if I2C is enabled by default on your board?
- Some hardware requires setting some configuration to enable specific peripherals/interfaces
- How are you powering the board, and the Bar30?
Note that the Bar30’s I2C address is 0x76 (not 0x40).
Yes so for power I am using pin 1 a 3.3v.
As you mentioned I am using pins 3 and 5 for SDA and SCL.
As far as I know I successfully installed smbus2 as before I was getting an error in VSCode that mentioned it wasn’t installed so I installed it using sudo apt-get install python3-smbus2 .
I will attempt at install through pip and update you.
I will have to check if i2c is enabled by default and get back to you.
Jetson Orin Nano is powered by its adapter thats plugged straight into a wall outlet.
The bar30 sensor is powered from pin 1 which is 3.3v from the Jetson.
Thank you I found something in the datasheet that only mentions 0x40 so I assumed that was the address.
@EliotBR Any idea how I can continue debugging this?
I have tested the Sensor on the Raspberry Pi 4 using the python library.
I ran i2cdetect -y 1 and once again 0x40 is detected when the sensor is plugged in on bus 1.
Could this sensor be faulty? I know the address is supposed to be 0x76 but this address never appears when the sensor is disconnected and reconnected only 0x40 does. Running out of ideas trying to get this sensor to read depth.
I have a similar problem, when I run i2cdumb -y 7 0x76 it detects the sensor but when I run the python code I get a I/O error. I am running it on Ubuntu 22 on a Jetson Orin nano
Yea sadly I am not sure how to go about this fix. I have come to the realization I am using a bar100 rather then the bar30 which is why I am able to detect 0x40 as the address. However, I am still getting the I/O error even with the proper library.
I can easily read the pressure, temperature and depth data provided by the MS5837-30BA on the Raspberry Pi 4B using Dupont wires. However, when I switched to the Jetson Orin NX, I couldn’t succeed. I specifically tried again on the Raspberry Pi and confirmed that the sensor was not damaged. I also used the MPU6050 on the Jetson and was able to read it, so the Jetson is fine.
I connected the sensor to pins 1, 3, 5, and 9, and I’m sure the interface is correct.
I confirmed that the i2c on the Jetson is working. However, when I tried to read the MS5837, I didn’t see the numbers 76 or 77 on the i2c bus.
sudo i2cdetect -y -r 8(I try from 1 to 11)
only see - -
I asked ChatGPT and was told that pull-up resistors were needed. I added 4.7kΩ resistors between SDA and SCL and VCC as required, but it still didn’t work.
I’m very confused. What’s going on here?
then i tried i2cdump
