I am trying to run the Bar30 (PCB) with a Teensy 3.2, but there is nothing happening over the i2c pins (checked with an oscilloscope). I am using the example code on the product page, and it is working fine when using an Arduino Due with the exact same code that i am trying to run on the Teensy. When running on Teensy, the values shown in the serial monitor are very unreasonable, and are still showing if i disconnect the sensor, so the sensor is not running at all.
The I/O pins on the Teensy are 3.3V. Cables are about 0.2m long.
Anyone know what might be the problem?
