I connected the sensor with the arduino uno board. It is giving the just giving me odd results. I am currently using it with the air. and it is giving me result like the following
Pressure: 36986596.00 mbar
Temperature: -2273.69 deg C
Depth: 378282.81 m
Altitude: -282744.53 m above mean sea level
The sensor operates at 3.3V max, the arduino operates at 5V. If you do not have a level shifter, the sensor will be damaged after connecting it to the arduino.
These sensors are also very sensitive to loose wires and connections. Low quality breadboards or jumper wires can present unexpected problems here. You should solder or crimp as many connections as you can.
