Modifying Frame Configuration
I am building a custom ROV, and have found that it yaws too quickly. I was thinking about altering the motor configuration and changing the yaw factor. Would I need to increase or decrease the value to decrease the speed at which it yaws? Is this the best way to do that?
Thanks,
Reza
There is no need to compile a new firmware. You can adjust the parameter ACRO_YAW_P to achieve the same effect.
Great, thank you so much
