Missing plugin on MSYS2 GStreamer (Windows)
Hi there,
I installed GStreamer using MSYS2 by following this tutorial.
I installed the necessary plugins on the tutorial and tried to run the following code (which is also in the tutorial):
from threading import Thread
from time import sleep
import gi
gi.require_version("Gst", "1.0")
from gi.repository import Gst, GLib
Gst.init()
main_loop = GLib.MainLoop()
thread = Thread(target=main_loop.run)
thread.start()
pipeline = Gst.parse_launch("udpsrc port=5600 ! application/x-rtp,media=video,clock-rate=90000,encoding-name=H264,payload=96 ! rtph264depay ! avdec_h264 ! appsink")
pipeline.set_state(Gst.State.PLAYING)
try:
    while True:
        sleep(0.1)
except KeyboardInterrupt:
    pass
pipeline.set_state(Gst.State.NULL)
main_loop.quit()
But I get the following error:
gi.repository.GLib.GError: gst_parse_error: no element "avdec_h264"
I had this issue before and I remember solving it by installing gst-libav and some other similar GStreamer packages.
I tried to install every possible package that I can think of in MSYS like:
pacman -S mingw-w64-x86_64-gst-libav
But none of them solved my issue. Maybe there are some other problems other than missing packages but maybe I’m just simply missing a package. I don’t know.
Any kind of help is highly appreciated. Thanks everyone in advance.
@EliotBR Hello Eliot,
I got no replies since the opening of this topic.
I started to wonder if I opened the topic in the wrong place, so I just wanted to ask if you can check and move the topic to it’s correct place (maybe somewhere more “general”) if necessary. Of course, I can just reopen it if you can suggest a better place.
Thanks for your time.
Hi @salihozdemir,
We did not write that tutorial, so you may be better served by contacting the tutorial author, or searching online for your error traceback.
From a brief look, you seem to be installing libraries for a Windows 10, 64-bit Intel-x86 computer. Does that match the device you’re running on? If you’re using a different system (e.g. Windows 11, or 32-bit Windows 10, or on an ARM chip instead of Intel) then the instructions there may not apply.
From a search of your error message it seems someone (on StackOverflow) has previously had a similar error, but it was not resolved.
We have our own OpenCV/gstreamer tutorial, but it is targeted at Linux environments. You may wish to consider trying Ubuntu on your computer via WSL2 - Windows can often be a bit extra challenging for software development.
From looking at the timestamps, you created the topic at ~11pm my time on Thursday evening, then I didn’t have time to respond to this post on my Friday, and today is Monday, when I have responded.
I expect others on the forum have not provided responses because the topic is quite niche, and is reasonably unrelated to what most of the community here has expertise in.
I have however also moved your post to the “General Discussion” category, because Gstreamer is not a Blue Robotics software, and your problem is unrelated to the ArduSub autopilot firmware which Blue Robotics helps to develop :slight_smile:
Hello Eliot.
Thank you for that.
I was frustrated with this problem for the last couple of days. I figured it out this morning, and just I like I guessed, it was so simple.
I told you that instead of building OpenCV with GStreamer, I had decided to go with MSYS2.
I am not sure of this analysis but I think that my environment variables (which I added after installing regular GStreamer for Windows for my previous attempt) was causing the problem. After removing GStreamer bin and lib folders from environment variables, I had no more missing GStreamer plugin errors.
Even though I had a different python interpreter inside MSYS2 environment, it was still using those environment variables I had and it was trying to use the GStreamer in the Windows, not in the MSYS2 environment.
So the tutorial had no problem and it was my fault. :sweat_smile: Problem is solved.
Thank you again for your efforts.
