Missing parameters, no parameter for lights, how to fix?
Having this issue with missing parameter message all the time with latest stable ardusub 4.5.3 on the latest stable QGC 4.4.4
Also, can see options for channel number in lights setup, it required BRD_PWM_COUNT parameter which is missing as well.
Any suggestion how to fix it?
Just found it in the blueos setup in the vehicle setup tab ->configure → lights where you can set the the channels.
Hi @nurjan14,
For some relevant context:
Note that our currently latest recommended (read: thoroughly tested) QGroundControl version is 4.2.8, although our development efforts are now focused on Cockpit instead, so QGroundControl is effectively a working fallback/alternative for situations where Cockpit is not yet sufficient.
hi@Eliot
Thanks you for that suggestion, I face this BRD_PWM_COUNT issue when I was trying to tune the PID for a custom ardusub-stable( 4.5.5) . After switching from QGCS 5.06 to 4.2.8, I can now tune my PID. By the way, is there any tool or software to automatically tune a sub vehicle attitude and position PID like the “PID Tunning” tool of PX4 in QGroundControl ?
I’m not aware of one, but I’ve raised an Issue about adding PID tuning support to BlueOS, which it might be worth referring to for links on how other ArduPilot firmware approach tuning (as some of the approaches may work similarly).
