hi i try to do some operation with mavros ros2
hardware - i am connect telem 433 of holybro to linux computer with joystick and try to run this node and script(add at the end):
- mavros node:
ros2 run mavros mavros_node --ros-args -p fcu_url:=/dev/ttyUSB0:57600 -p gcs_url:=udp://@192.168.1.142:14550 -p sysid:=1 - joy node
3)script (at the end)
i try with another widows computer to connect via udp and check if i get radio at the radio calibartion and i dont get any information
i try to run this script at px4 with sitl and get data about the controller
the script:
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Joy
from mavros_msgs.msg import OverrideRCIn # Ensure this is the correct message type
import time
class RCOverrideNode(Node):
def __init__(self):
super().__init__('rc_override_node')
self.publisher_ = self.create_publisher(OverrideRCIn, '/mavros/rc/override', 10) # Update the publisher to OverrideRCIn
self.joy_subscription = self.create_subscription(
Joy,
'/joy',
self.joy_callback,
10
self.joy_subscription # prevent unused variable warning
# Call reset_parameters once at startup
self.reset_parameters()
def reset_parameters(self):
# Set all channels to 65535 at the start to indicate no override
rc_override = OverrideRCIn()
rc_override.channels = [65535] * 12 # Assuming 12 channels
self.publisher_.publish(rc_override)
self.get_logger().info('RC Override parameters reset to 65535')
time.sleep(2)
rc_override.channels = [0] * 12 # Assuming 12 channels
self.get_logger().info('RC Override parameters reset to 0')
def joy_callback(self, msg):
rc_override = OverrideRCIn() # Create an instance of OverrideRCIn
# Map joystick axes/buttons to RC channels
self.scale_value(msg.axes[0], -1.0, 1.0, 1000, 2000), # Roll (Ch1)
self.scale_value(msg.axes[1], -1.0, 1.0, 1000, 2000), # Pitch (Ch2)
self.scale_value(msg.axes[2], -1.0, 1.0, 1000, 2000), # Throttle (Ch3)
self.scale_value(msg.axes[3], -1.0, 1.0, 1000, 2000) # Yaw (Ch4)
# Debug statements
self.get_logger().info(f'Joy axes: {msg.axes}')
self.get_logger().info(f'RC Override: {rc_override.channels}')
# Publish the RC override message
@staticmethod
def scale_value(value, src_min, src_max, dst_min, dst_max):
# Scale value from source range to destination range
src_range = src_max - src_min
dst_range = dst_max - dst_min
scaled_value = ((value - src_min) * dst_range) / src_range + dst_min
return int(scaled_value)
def main(args=None):
rclpy.init(args=args)
node = RCOverrideNode()
rclpy.spin(node)
node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
i think i got some problem with the callibration of my fc
thanks for the help
Mavros: 2.7.0
ROS: iron
Ubuntu: 22.04
Autopilot type and version
[ X ] ArduPilot
[ ] PX4
Version: 4.4.0
Diagnostics
header:
stamp:
sec: 1718367553
nanosec: 449656643
frame_id: ''
status:
- level: "\0"
name: 'mavros: MAVROS UAS'
message: connected
hardware_id: uas:///uas1
values: []
- level: "\x02"
message: No satellites
values:
- key: Satellites visible
value: '0'
- key: Fix type
value: '0'
- key: EPH (m)
value: Unknown
- key: EPV (m)
value: Unknown
- level: "\x01"
message: Can not diagnose in this targeting mode
values:
- key: Mode
value: '255'
- level: "\x02"
message: Sensor health
values:
- key: Sensor present
value: '0x5330FC0F'
- key: Sensor enabled
value: '0x52209C0F'
- key: Sensor health
value: '0x43109C0B'
- key: 3D gyro
value: Ok
- key: 3D accelerometer
value: Ok
- key: 3D magnetometer
value: Fail
- key: absolute pressure
value: Ok
- key: 3D angular rate control
value: Ok
- key: attitude stabilization
value: Ok
- key: yaw position
value: Ok
- key: motor outputs / control
value: Ok
- key: AHRS subsystem health
value: Fail
- key: Battery
value: Ok
- key: pre-arm check status. Always healthy when armed
value: Fail
- key: propulsion (actuator, esc, motor or propellor)
value: Ok
- key: CPU Load (%)
value: '31.0'
- key: Drop rate (%)
value: '0.0'
- key: Errors comm
value: '0'
- key: 'Errors count #1'
value: '0'
- key: 'Errors count #2'
value: '0'
- key: 'Errors count #3'
value: '0'
- key: 'Errors count #4'
value: '0'
- level: "\0"
message: Normal
values:
- key: Voltage
value: '12.40'
- key: Current
value: '-0.1'
- key: Remaining
value: '99.0'
- level: "\0"
name: 'mavros: Heartbeat'
message: Normal
values:
- key: Heartbeats since startup
value: '106'
- key: Frequency (Hz)
value: '1.000003'
- key: Vehicle type
value: Quadrotor
- key: Autopilot type
value: ArduPilot
- key: Mode
value: STABILIZE
- key: System status
value: STANDBY
- level: "\0"
name: 'mavros: 3DR Radio'
message: Normal
values:
- key: RSSI
value: '145'
- key: RSSI (dBm)
value: '-50.7'
- key: Remote RSSI
value: '141'
- key: Remote RSSI (dBm)
value: '-52.8'
- key: Tx buffer (%)
value: '100'
- key: Noice level
value: '56'
- key: Remote noice level
value: '65'
- key: Rx errors
value: '5'
- key: Fixed
value: '0'
header:
stamp:
sec: 1718367554
nanosec: 443034005
frame_id: ''
status:
- level: "\0"
name: 'mavros_router: MAVROS Router'
message: ok
hardware_id: none
values:
- key: Endpoints
value: '3'
- key: Messages routed
value: '5015'
- key: Messages sent
value: '9944'
- key: Messages dropped
value: '0'
- level: "\0"
name: 'mavros_router: endpoint 1000: /dev/ttyUSB0:57600'
message: ok
hardware_id: none
values:
- key: Received packets
value: '4591'
- key: Dropped packets
value: '0'
- key: Buffer overruns
value: '0'
- key: Parse errors
value: '0'
- key: Rx sequence number
value: '71'
- key: Tx sequence number
value: '0'
- key: Rx total bytes
value: '140357'
- key: Tx total bytes
value: '7877'
- key: Rx speed
value: '1605.000000'
- key: Tx speed
value: '59.000000'
- key: Remotes count
value: '5'
- key: Remote [0]
value: '0.0'
- key: Remote [1]
value: '1.0'
- key: Remote [2]
value: '1.1'
- key: Remote [3]
value: '51.0'
- key: Remote [4]
value: '51.68'
- level: "\0"
name: 'mavros_router: endpoint 1001: udp://@192.168.1.142:14550'
message: ok
hardware_id: none
values:
value: '292'
value: '0'
value: '0'
- key: Parse errors
value: '0'
value: '246'
value: '0'
value: '5640'
value: '142842'
- key: Rx speed
value: '38.000000'
- key: Tx speed
value: '1636.000000'
value: '3'
- key: Remote [0]
value: '0.0'
- key: Remote [1]
value: '255.0'
- key: Remote [2]
value: '255.190'
- level: "\0"
name: 'mavros_router: endpoint 1002: /uas1'
message: ok
hardware_id: none
values:
value: '3'
- key: Remote [0]
value: '0.0'
- key: Remote [1]
value: '1.0'
- key: Remote [2]
value: '1.191'
header:
stamp:
sec: 1718367554
nanosec: 449808470
frame_id: ''
status:
- level: "\0"
message: connected
values: []
- level: "\x02"
values:
value: '0'
- key: Fix type
value: '0'
- key: EPH (m)
value: Unknown
- key: EPV (m)
value: Unknown
- level: "\x01"
values:
- key: Mode
value: '255'
- level: "\x02"
values:
value: '0x5330FC0F'
value: '0x52209C0F'
value: '0x43109C0B'
- key: 3D gyro
value: Ok
value: Ok
value: Fail
value: Ok
value: Ok
value: Ok
- key: yaw position
value: Ok
value: Ok
value: Fail
- key: Battery
value: Ok
value: Fail
value: Ok
- key: CPU Load (%)
value: '31.0'
value: '0.0'
- key: Errors comm
value: '0'
value: '0'
value: '0'
value: '0'
value: '0'
- level: "\0"
message: Normal
values:
- key: Voltage
value: '12.40'
- key: Current
value: '-0.1'
- key: Remaining
value: '99.0'
- level: "\0"
message: Normal
values:
value: '107'
value: '0.999982'
- key: Vehicle type
value: Quadrotor
value: ArduPilot
- key: Mode
value: STABILIZE
value: STANDBY
- level: "\0"
message: Normal
values:
- key: RSSI
value: '136'
- key: RSSI (dBm)
value: '-55.4'
- key: Remote RSSI
value: '142'
value: '-52.3'
value: '100'
- key: Noice level
value: '57'
value: '65'
- key: Rx errors
value: '5'
- key: Fixed
value: '0'
Check ID
header:
stamp:
sec: 1718367767
nanosec: 147378560
frame_id: ''
connected: true
armed: false
guided: false
manual_input: true
mode: STABILIZE
system_status: 3
header:
stamp:
sec: 1718367768
nanosec: 206044287
frame_id: ''
connected: true
armed: false
guided: false
manual_input: true
mode: STABILIZE
system_status: 3
