Cactus
January 23, 2020, 4:41pm
1
As a project, I have to develop autonomous behaviour for a BlueROV1. I installed Mavros and Mavproxy on a Rpi2 but when I’m trying to publish on the rc/override topic with
rostopic pub -r 1 /mavros/rc/override mavros_msgs/OverrideRCIn '[1300, 1300, 1300, 1300, 0, 0, 0, 0]
it keeps answering "
RC override not supported by this FCU!"
I’m using QGroundControl as a GCS and I can us the Motor Test tool to monitor the pwm output.
For the Mavproxy configuration:
mavproxy.py --master=/dev/ttyACM0 --out=tcpin:0.0.0.0:65500 (MavRos) –out=udp:192.168.2.1:14550 (CGS)
For the MavROS configuration:
arg name=“fcu_url” default=“tcp://0.0.0.0:65500@”
arg name=“gcs_url” default=“”
So do you have any Idea why the RCOverride isn’t working ?
Thanks,
Cactus
Take a look in our pymavlink examples and try to test Send RC (Joystick) example.
Let me know if it works, it may be a problem with mavros.
Cactus
January 24, 2020, 4:26pm
3
Thanks, I tried but this example as no effects on the /rc/out.
It still remains at:
“channels: [1500, 1500, 1500, 1500, 1500, 1500, 0, 0]”
Cactus
January 27, 2020, 9:50am
6
I managed to Override the RC channels with this configuration but as you can see some conflicts occures for the serial port of the pixhawk.
Cactus
7
So I changed the setup and there’s no conflicts remaining but the Override topic is no longer functional.
Try to close QGC and test you script with the Pixhawk <-> Mavproxy <-> Mavros pipeline alone.
Cactus
January 27, 2020, 12:58pm
9
I deleted the Mavproxy connection and here’s what I have.
Cactus
January 29, 2020, 10:45am
10
Should the rC/override change the input values or just the out values because the rc/in topic stays empty despite the override.
