Goal: to arm the vehicle and put it in a mode, say ACRO, and while in that mode have my laptop running a pymavlink script process camera images, calculate corresponding pitch, roll, yaw and thrust to send to the Pixhawk in order autonously steer the vehicle towards a target.
Approach: Using the set pwm rc override commands to transmit 1100-1900 pwm’s on rc channels 1-4.
Problem: the motors only activate for a few seconds and then stop rotating.
The following script I’m using is a compilation of scripts found here.
from pymavlink import mavutil
############################################################## function to send RC values
def set_rc_channel_pwm(id, pwm=1500):
""" Set RC channel pwm value
Args:
id (TYPE): Channel ID
pwm (int, optional): Channel pwm value 1100-1900
if id < 1:
print("Channel does not exist.")
return
# We only have 8 channels
#http://mavlink.org/messages/common#RC_CHANNELS_OVERRIDE
if id < 9:
rc_channel_values = [65535 for _ in range(8)]
rc_channel_values[id - 1] = pwm
master.mav.rc_channels_override_send(
master.target_system, # target_system
master.target_component, # target_component
*rc_channel_values) # RC channel list, in microseconds.
# Create the connection
master = mavutil.mavlink_connection('udpin:192.168.2.1:14550')
# Wait a heartbeat before sending commands
master.wait_heartbeat()
############################################################## Arm
master.mav.command_long_send(
mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM,
0,
1, 0, 0, 0, 0, 0, 0)
#############################################################set mode :
# Choose a mode
mode = 'ACRO'
# Check if mode is available
if mode not in master.mode_mapping():
print('Unknown mode : {}'.format(mode))
print('Try:', list(master.mode_mapping().keys()))
exit(1)
# Get mode ID: return value should be 1 for acro mode
mode_id = master.mode_mapping()[mode]
master.mav.set_mode_send(
mavutil.mavlink.MAV_MODE_FLAG_CUSTOM_MODE_ENABLED,
mode_id)
############################################################# Set some ptich
set_rc_channel_pwm(1, 1600)
Thanks Patrick! That works. However, is there a command to set pitch rate, roll rate, yaw rate and throttle that doesn’t require periodically updating?
No, this is a safety mechanism. You can disable the failsafe for pilot input or gcs failsafe to override this. Be careful with that route though; it’s set up this way for a reason.
I did disable those two failsafes using QGC, however i still need to periodically set the channel at a quite fast rate in order to keep the thrusters continuously spinning. Is there something else I need to disable in order to be able to set and forget?
Is there a way to set the rc channel without having to periodically update it? I have disabled pilot input and gcs in QGround Control to no avail however.
Hi Jacob: I have firmware version 3.5.2 installed. The interval method is computationally cumbersome for application. Is there a way to be able to bypass that requirement? As I mentioned, I disabled pilot input and gcs heartbeat.
mavutil.set_dialect("ardupilotmega")
# Set all rc chans pwm to 1500 before arming:
data = [ 1500 ] * 8
master.target_system, master.target_component, *data)
#############################################################set mode:
# Choose a mode
mode = 'MANUAL'
# Set new mode
mode_id)
1,
data[2] = 1600 # set some throttle
master.mav.rc_channels_override_send(master.target_system, master.target_component, *data)
This should not be much overhead, you only have to send the message around ~1Hz. This will ensure your ROV doesn’t run away from you during your experiments :).
