Thanks for the reply Jacob.
My projects gstreamer pipeline currently defaults to /dev/video2 for its v4l2src and I am looking for a way to dynamically select the H264 v4l2 device I should be using here. This is important because if the USB disconnects like I described in the previous post my live stream will be down. I want to fall back onto the next available v4l2 device that supports H264 video capture from my BlueRobotics Low-Light HD USB Camera.
My gstreamer pipeline starts like this:
gst-launch-1.0 v4l2src device=/dev/video2 ...
I noticed after reading your comment that the video capture device will swap to /dev/video3 if the USB disconnects on /dev/video2. Conversely, When /dev/video2 is connected, /dev/video3 cannot be used for the gstreamers video capture device. I was able to determine this after I ran v4l2 commands on two nodes, one with the USB connected as expected and one without. I attached the output that details this behavior below.
I also wanted to note that I still have not been able to recover the /dev/video2 device once it disappears without rebooting the RPi. You mentioned "What you need to do is close the /dev/video2 file after the camera disconnects (there are a number of ways of detecting and accomplishing this". I was hoping you could provide more details on this, as I have not been successful in recovering access to the /dev/video2. If theres a way to dynamically select the active v4l2 device that is being used for H264 video capture then no matter how many potential USB disconnects could occur I would be able to fall back onto a valid v4l2 device for my live stream. Assuming something like this is possible, I would like to implement this.
Possible Solution:
I’m thinking of iterating over each /dev/video* device and checking for the output of the command v4l2-ctl --list-formats --device /dev/video*. The v4l2 device I want to use should output a response that contains the string [0]: 'H264' (H.264, compressed). This seems to correlate to the v4l2 device that can actively be used for H264 video capture in my gstreamer pipeline.
Does this sounds like the right approach? Would love to get your feedback on this, or if you think think there is a better solution to this problem I’ve been facing. Let me know if I can provide any additional information that I may not have provided below.
P.S
Additionally it would be nice to probe the buffer to determine if the sensor is even reading data from the v4l2 device. I’ve had a couple Low-Light HD USB Camera go bad, the sensor stops readings data and when that happens the gstreamer pipeline fails silently because it can open the video device but no data is coming through. When this has happened in the past I’ve just swapped it out for a new Low-Light HD USB Camera.
—————————————— on device with /dev/video2 (expected) —————————————————
v4l2-ctl --list-devices
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
H264 USB Camera: USB Camera (usb-3f980000.usb-1.1.2):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
v4l2-ctl --list-formats --device /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
[1]: 'YUYV' (YUYV 4:2:2)
v4l2-ctl --list-formats --device /dev/video1
Type: Video Capture
v4l2-ctl --list-formats --device /dev/video2
Type: Video Capture
v4l2-ctl --list-formats --device /dev/video3
Type: Video Capture
—————————— on device with /dev/video2 disconnected (unexpected) ——————————
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
H264 USB Camera: USB Camera (usb-3f980000.usb-1.3):
/dev/video0
/dev/video1
/dev/video3
/dev/video4
Type: Video Capture
Type: Video Capture
Cannot open device /dev/video2, exiting.
Type: Video Capture
—————————— Full Dmesg Output (This is on RPi with the USB Disconnect) —————————
[Mon Apr 5 09:11:04 2021] uvcvideo: Found UVC 1.00 device H264 USB Camera (32e4:9422)
[Mon Apr 5 09:11:04 2021] input: H264 USB Camera: USB Camera as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
[Mon Apr 5 09:11:04 2021] usbcore: registered new interface driver uvcvideo
[Mon Apr 5 09:11:04 2021] USB Video Class driver (1.1.1)
[Mon Apr 5 09:11:04 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[Mon Apr 5 09:11:04 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[Mon Apr 5 09:11:04 2021] usb 1-1.3: 4:1: cannot get freq at ep 0x84
[Mon Apr 5 09:11:04 2021] usbcore: registered new interface driver snd-usb-audio
[Mon Apr 5 09:11:06 2021] uart-pl011 3f201000.serial: no DMA platform data
[Mon Apr 5 09:11:06 2021] random: crng init done
[Mon Apr 5 09:11:06 2021] random: 7 urandom warning(s) missed due to ratelimiting
[Mon Apr 5 09:11:06 2021] 8021q: 802.1Q VLAN Support v1.8
[Mon Apr 5 09:11:07 2021] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[Mon Apr 5 09:11:07 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[Mon Apr 5 09:11:07 2021] 8021q: adding VLAN 0 to HW filter on device eth0
[Mon Apr 5 09:11:07 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[Mon Apr 5 09:11:13 2021] Bluetooth: Core ver 2.22
[Mon Apr 5 09:11:13 2021] NET: Registered protocol family 31
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI device and connection manager initialized
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI socket layer initialized
[Mon Apr 5 09:11:13 2021] Bluetooth: L2CAP socket layer initialized
[Mon Apr 5 09:11:13 2021] Bluetooth: SCO socket layer initialized
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI UART driver ver 2.3
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI UART protocol H4 registered
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
[Mon Apr 5 09:11:13 2021] Bluetooth: HCI UART protocol Broadcom registered
[Mon Apr 5 09:11:13 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Mon Apr 5 09:11:13 2021] Bluetooth: BNEP filters: protocol multicast
[Mon Apr 5 09:11:13 2021] Bluetooth: BNEP socket layer initialized
[Tue Apr 6 04:15:35 2021] usb 1-1.3: USB disconnect, device number 4
[Tue Apr 6 04:15:35 2021] uvcvideo: Failed to resubmit video URB (-19).
[Tue Apr 6 04:15:36 2021] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[Tue Apr 6 04:15:36 2021] usb 1-1.3: New USB device found, idVendor=32e4, idProduct=9422, bcdDevice= 1.00
[Tue Apr 6 04:15:36 2021] usb 1-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[Tue Apr 6 04:15:36 2021] usb 1-1.3: Product: H264 USB Camera
[Tue Apr 6 04:15:36 2021] usb 1-1.3: Manufacturer: H264 USB Camera
[Tue Apr 6 04:15:36 2021] usb 1-1.3: SerialNumber: 2020032801
[Tue Apr 6 04:15:36 2021] uvcvideo: Found UVC 1.00 device H264 USB Camera (32e4:9422)
[Tue Apr 6 04:15:36 2021] input: H264 USB Camera: USB Camera as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
[Tue Apr 6 04:15:36 2021] usb 1-1.3: 4:1: cannot get freq at ep 0x84
