Can the Ardusub firmware process mavlink message of type vision_position_estimate. I have an onboard VIO system that produces position estimates, which is then published over mavros, as discussed here. But the sent mavlink message can’t be found in the mavlink inspector. Does ardusub support mavlink messages of type vision_position_estimate?
Related topics
| Topic | Replies | Views | Activity | |
| Integrating extarnal sensors into Ardusub with mavlink | 2 | 217 | May 15, 2025 | |
| Integrating external SLAM through VISION_POSITION_ESTIMATE. GUIDED mode fails to kick on. position_ok() check fails | 1 | 2337 | March 6, 2021 | |
| ArduSub Visual Odometry | 2 | 1400 | September 6, 2022 | |
| Pixhawk not sending local position depite feeded by VISION_SPEED_ESTIMATE message | 0 | 93 | August 15, 2024 | |
| Does Ardusub use Inertial and Compass data from the DVLA50? | 1 | 965 | September 20, 2021 |
