Lights quit working?
Okay, I installed my newton gripper and updated my software. Everything works as before except my lights?
Things I have done: reloaded default configuration, tested lights by jumping signal wire to 12v, signal wire connected to main output channel 7 on pixhawk, lights 1 set to channel 7, and I can see servo7_raw parameter change in the MAVlink Inspector. What am i missing?
Thanks. Jake
Hi Jake,
Quick Start (on/off with no PWM signal source)
Connect the power wires to a power source
Red: +10-48 volts
Black: Ground
Connect the yellow signal wire to the the power wire directly or through a switch to turn on to full brightness
The lights are not working when you do this ?
Hi Patrick, The lights do work when I do “Quick Start on/off with no PWM signal source”
A strange new problem has presented itself as I continue to troubleshoot this problem:
One lumen light (the last light in the chain) starts to flicker at the 63% step and then is steady at 75%, 88% and 100%. I have 8 brightness steps set in the set-up tab. But when I do the quick start and connect the signal wire to +12V they both light up. My battery voltage for testing is 16.4V.
I know, weird.
Thanks, Jake
@patrickelectric
I had another set of lights and used those to troubleshoot my issue. They worked as expected so I decided to open up my lights to see if there was any signs of water ingress. This is what I found:
It appears that there is some corrosion from a small amount of water ingress. Should I attempt to clean the contacts and reassemble the light?
Hi Jake,
This appears to be an infiltration issue, please contact support@bluerobotics.com with this pictures for replacement.
@patrickelectric
Thank you Patrick, I will contact support.
Jake
