When I connect the joystick to my computer (USB connection), QGC cannot find and I cannot fine the joystick page as described in the manual. I have tried in both mac and windows. What should I do?
I have found that I need the joystick plugged in and recognised by computer before starting QGC. Been consistent that way otherwise I have to reboot QGC if I connect controller after QGC running.
Hope that helps
If you’re using Windows then the joystick needs to be X-Box compliant. At some point I hope they change this as it would be better to support other types of joysticks as well.
thank you. I will try that and I will get back
