It is interesting that you began to experience problems with the Depth Hold mode since you calibrated your accel/compass sensors.
I believe that Depth Hold is controlled by the Bar30 High Resolution 300m Depth/Pressure Sensor and should not be affected by the accel/compass sensor calibration.
You might want to try and recalibrate the Depth/Pressure Sensor to see if that will cure you Depth Hold mode issue.
Regardless of the direction of the vertical thrusters, when triggering the automatic depth out of water with the depth sensor zeroed, vertical thrusters should not operate.
Yes, I already tested it inside the pool and the problem is in the automatic depth that, when triggered, is triggering the vertical thrusters to the bottom of the pool.
An interesting detail, when I turn on the automatic depth and the verticals begin to rotate, I tilt the rov 45 degrees with the nose down and the verticals stop turning.
We reverse the propellers of thrusters 2 and 4 to avoid there being a twist in the frame or until the rov drifts when it goes forward.
The thruster 5 was reversed because the rotation was to the same side of the thruster 6.
Geraldo, You should not try to test the STABILIZE mode or the DEPTH HOLD mode when the ROV is sitting in the air. The motors will always turn if this is the case. To use or test these modes, the ROV must be in the water.
When the ROV is in the water, if DEPTH HOLD makes the rov go up or down quickly, it means that the motor direction is incorrect. Then you should change the direction of motors 5 and 6, and try to use depth hold again while the ROV is in the water.
Please follow the instructions on the motor setup page carefully. If you believe there is some other problem, please make a video demonstrating that it does not work with the motors 5 and 6 in either configuration.
But do not you agree that vertical thrusters, even in the air, when triggered the automatic depth, should they not stand still, whether they are inverted or not?
There is no variation of the depth sensor!
Are there other sensors that work with Depth Hold?
What I find strange now is to put the ROV at 45 degrees and the vertical thrusters stop and when I change the value of the depth sensor in that position, it works normally.
There is variation of the depth sensor (maybe a smaller decimal place than the display in QGC), as well as the IMU sensors, which the ROV combines all this information to find “how deep am I”. The ROV will try to correct for even a fraction of a centimeter. Not only do the verticals run for depth, but they also run to correct the roll angle. And this will try to correct for even a fraction of a degree out of ‘perfectly level’. This is why the motors spin in air, and this is why they are expected to spin (because the output does not help to correct the error), and that’s ok.
It is a result of the closed loop control algorithm and the feedback that the ROV received from the sensors. When you tilted it forward, you probably leveled it on the roll axis.
I will leave some suggestions for future implementation in the software.
1 - Possibility to use only the depth sensor in the Depth Hold (Since that ROVs are naturally roll and pitch stable in water it does not need to use accelerometers readings to compute Depth Hold, just the pressure and sonar altimeter if installed);
2 - Possibility to use Depth Hold and Stabilize together, with specific buttons to disable them.
