It’s connected to the topside using ethernet connector, the rest is correct.
It works really well.
Cheers
Jan R
Cheers
Jan R
Thanks ! how do you get ethernet out of the topside ?
I connect directly to the LX200V20 board.
I made a spool with this inside, and connector on the outside. Then on the Ubiquity there is a pass through so I can have both wireless and wired at the same time.
Cheers
Jan R
Awesome, i’ll try to do the same as it seems to be the best combo with BlueROV2 and CrystalSky for field missions in a sunny and salty environment.
Last question: how do you power the topside and Ubiquity when away from a laptop or wall socket ?
Also, do you mind sharing a few photos of your modified topside and set up ? Thanks !
I have a 3s battery inside the spool, also using a DC/DC converter to power the AC Pro.
I connect the battery balance wires to a connector outside of the spool so it’s easy to charge.
This setup works for several hours in the field.
I will see if I can find some pictures of the setup.
Cheers
Jan R
Hi Jan, did you find a photo of your setup? I’m looking into buying an AC Pro but it seems i also need a Unifi Cloud Gateway between the LX200V20 board and the AC Pro access point. I would really like to see what your setup looks like. Thanks !
Sorry about this but I don’t have any photos of the setup.
You don’t need anything other than the voltage injector for the Ubiquity.
Cheers
