The Bar30 I2C address is set by hardware, unless you got the bare pcb version, it cannot be changed. The example code does print the values on the serial monitor, can you explain more about what you want to do?
@jwalser, need change something on the firmware of pixhawk? I try many times, but on the parameters on QGC not show Pressure parameter and give fail on calibration of baro.
I use an 16bar sensor, output 0-5V, 0-10v or 4-20mA. The Ads1115 convert to digital on the addres 0x48, 0x4A, 0x4B or 0x49. I believe that the 30Bar bluerobotics use other addres to read the pressure. I’m not sure if this is the problem.
I try to use this setup, because have this conversor e pressure sensor in brazil, and for import the MS5837 will be complicated, because the time and our Mail service that are very bad here.
You can put in a feature request for analog pressure sensors via ‘github issues’ if you want. The best way to get some support for it is to share some hardware that could be used. I think you should leave the idea of using the ads1115 alone for now, it won’t help with anything.
