I am a newbie on this. I am trying to get video to qgroundcontrol from raspberry pi camera. I figure out all the raspberry pi end but not the video in the qgroundcontrol. I downloaded qgroundcontrol from here:
But once I run qgroundcontrol with pikhawk and raspberrypi, everything works fine, but I don’t see any option to select a display and see the video stream in qgroundcontrol comming from raspberrypi. Does somebody now how to set that up in qgroundcontrol?
But on the qgroundcontrol, I don’t even know how to set up and open a window there to see video. I only see the google map and the gps location and the rest of the controls working properly, but no video window.
You need to install gstreamer on the machine running qgc, then build from source. The precompiled downloads don’t include video support. See the instructions here: https://github.com/mavlink/qgroundcontrol/blob/master/src/VideoStreaming/README.md
Once built, there is a little rectangle in the lower left of the map that will show the video. If you click the rectangle it will replace the map with fullscreen video.
-Jacob
Thanks Jacob. I follow all the steps and I got now the qgroundcontrol with an image window. However, now on the raspberry pi I get stuck with Pipeline is PREROLLING …
this is the command I use on the raspberrypi (I have a raspberry pi camara connected to the raspberry pi)
We have everything on our BlueROV running except for the camera in Qgroundcontrol. Our RBpi is streaming to port 5600. On our windows 7 PC we can see binary data comming in on UDP port 5600 (in terminal program).
We have the latest daily build of QGC installed and after this installed the latest version of Gstreamer (1.8.2). When starting QGC we don’t see video appearing in the video window. Do we have to apply any settings in QGC or should this work automatically?
I’ve had some trouble getting the video streaming to work with Windows as well. I think that feature just got added to the daily build recently. I’ll look into it and see if there’s anything that needs to be done differently for it to work. It should work automatically once the vehicle is connected.
Can you tell me what command you are using to initiate the streaming? Is your Windows computer set to the right IP address?
The remote IP is set to the IP adress of the computer running QGC so this should be ok. I have also added port 5600 as an exception in the firewall. Is there any other way to check if the data is received by the PC correctly?
Okay. That should be correct, but as I mentioned, I haven’t gotten this to work on Windows yet either. That’s pretty high on my list right now so I’ll try to test this out and figure out a solution soon.
I am still having trouble getting camera feed to run in QGC on my windows 7 computer. I am getting camera feed on and off but it is never consistent. Is there something I need to do to fix this issue and resolve the camera feed? Have you found a solution for windows users?
Madi, what version of QGC are you running? Try installing the latest version and see if you still have issues. If you do, is it possible to try with another computer in order to narrow down the possible causes of your problem?
-Jacob
Hi. Hoping you can also help me, Rusty. I am having trouble getting the video from my raspberry pi camera to stream in QGroundControl.
When I enter in your code everything looks to be alright.
I have:
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock; GstSystemClock
That’s it.
I do not have video streaming. I don’t know what to do and Emlid Docs don’t really tell me much. Wondering if you can shed some light on this problem.
You need to make sure the pi and the computer/tablet are on the same network.
You need to find the IP address of the computer that you want to send video to.
You need to change the command and fill in your computer’s IP address.
You need to set QGC video settings to UDP video stream, and make sure the port matches the command you enter on the Pi (9000 here). The video settings are on the General tab of the Application Settings page (click the ‘Q’ icon).
Alright, mate. I’ll have a look at those settings. I was using something other than 9000 in the QGS, 14550, or something. I have changed that to 9000 now.
I have a connection with QGC. Connecting to this isn’t the problem. The main issue is all the things I need to do and match. Things for the PC (don’t even go to android just yet!) I need to download and install. Not sure if that is done correctly. Also, what’s up with all this:
Pipeline
For the time being, the pipeline is somewhat hardcoded, using h.264. It’s best to use a camera capable of hardware encoding h.264, such as the Logitech C920. On the sender end, for RTP (UDP Streaming) you would run something like this:
gst-launch-1.0 uvch264src initial-bitrate=1000000 average-bitrate=1000000 iframe-period=1000 device=/dev/video0 name=src auto-start=true src.vidsrc ! video/x-h264,width=1920,height=1080,framerate=24/1 ! h264parse ! rtph264pay ! udpsink host=xxx.xxx.xxx.xxx port=5600
Where xxx.xxx.xxx.xxx is the IP address where QGC is running. You may tweak the bitrate, the resolution and the FPS based on your needs and/or available bandwidth.
To test using a test source on localhost, you can run this command:
