acces attemp bluerov
VM to bluerov
viki@c3po:~$ ssh ubuntu@bluerov
ssh: Could not resolve hostname bluerov: Name or service not known
valid access
viki@c3po:~$ ssh ubuntu@10.0.0.20
ubuntu@10.0.0.20’s password:
Welcome to Ubuntu 14.04.3 LTS (GNU/Linux 3.18.0-20-rpi2 armv7l)
- Documentation: https://help.ubuntu.com/
Last login: Thu Jan 1 00:42:12 1970 from 10.0.0.10
ubuntu@bluerov:~$
Ping example bluerov to VM
ubuntu@bluerov:~$ ping 10.0.0.10
PING 10.0.0.10 (10.0.0.10) 56(84) bytes of data.
64 bytes from 10.0.0.10: icmp_seq=1 ttl=64 time=0.709 ms
64 bytes from 10.0.0.10: icmp_seq=2 ttl=64 time=0.517 ms
Ping example VM to bluerov
viki@c3po:~ ping 10.0.0.20
PING 10.0.0.20 (10.0.0.20) 56(84) bytes of data.
64 bytes from 10.0.0.20: icmp_seq=1 ttl=64 time=0.607 ms
64 bytes from 10.0.0.20: icmp_seq=2 ttl=64 time=1.94 ms
<strong>ifconfig in VM</strong>
viki@c3po:~ ifconfig
eth0 Link encap:Ethernet HWaddr 08:00:27:b4:6c:dd
inet addr:10.0.0.10 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::a00:27ff:feb4:6cdd/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3487 errors:0 dropped:0 overruns:0 frame:0
TX packets:1447 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:460077 (460.0 KB) TX bytes:148828 (148.8 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4538 errors:0 dropped:0 overruns:0 frame:0
TX packets:4538 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:625231 (625.2 KB) TX bytes:625231 (625.2 KB)
if config in bluerov
ubuntu@bluerov:~$ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:10:ce:6d
inet addr:10.0.0.20 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe10:ce6d/64 Scope:Link
RX packets:769 errors:0 dropped:0 overruns:0 frame:0
TX packets:241 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:95742 (95.7 KB) TX bytes:34871 (34.8 KB)
RX packets:40 errors:0 dropped:0 overruns:0 frame:0
TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3024 (3.0 KB) TX bytes:3024 (3.0 KB)
interfaces file
ubuntu@bluerov:~$ cat /etc/network/interfaces
interfaces(5) file used by ifup(8) and ifdown(8)
Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
#allow-hotplug eth0
#iface eth0 inet dhcp
ROV direct connection
auto eth0
iface eth0 inet static
address 10.0.0.20
netmask 255.255.255.0
hosts file
ubuntu@bluerov:/etc/network$ cat /etc/hosts
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 ubuntu
10.0.0.20 bluerov
hostname file
ubuntu@bluerov:cat /etc/hostname
bluerov
I think I should include in Bluerov or VM some form of link both in the execution of Roscore
Something about
export ROS_MASTER_URI=_______________
but not which of the two and would have to put , I would also like it to work : ssh ubuntu"bluerov instead ssh ubuntu@10.0.0.20 because I think there must come the problem of communication between VM and bluerov.
Thank you very much to all the world
