Gripper utilities - line cutters
…arent those fragile?..is it possible to get theese to fit?images
…i have had theese in mind from the start about ropecutting bec they have seemd to work better for soft lines… but the Thether cutter is a Must have :wink: …i just wondered if you have tryed the Stanleyknives in the cutter?..its a way stronger blade, but maby not sharp enough?
companion-f-serrated-produkt … i did weld two like this (se theblade) years ago on a small job, and it worked very well :slight_smile: … but still thats only for soft ropes.! it wont to for tether.
Yes we can redesing for fit this blade
How many cutter do you need?
i only need one for now, but have you tried with the stanley knife?
i desing the first one with this blade becose i have other cutter line from videoray rov and we uses this blade, and work perfect fot tether cuts.
I see other cutter lines with stanley blades but i never tried.
i gona make new desing with stanley blades and test is the result is good and of i gona let you know
Hey Alain,
Any luck with the line cutter attachment?
Has this site moved or perhaps down temporarily ?
We are looking for a tool capable of cutting a 20mm dyneema line and are currently researching any ready built options.
Just noticed thats a post from 4 years ago that I’ve replied to :blush:
They’re now called Reach Robotics, https://reachrobotics.com/
Rich
I like this idea - means that the cutting tool is only effective when switched on so reduces potential damage to the target or the ROV tether. :+1:
