Gripper installation
Hi everybody,
I am trying to install my new gripper but I have no action to the gripper at all. I have installed it using the instructions. I have tried the channel 1 and 3 and the buttons of the joystick 9 and 10 with and without shift function. I have checked that I have 15v to the power terminals…
Have you any idea what to try? Everything else is working like charm.
Thank you in advance!
@nmau,
I assume:
The yellow wire on the servo cable is plugged into either the bottom pin of aux servo channels 1 or 3
You have setup the following button functions:
servo_X_max_momentary (open while pressed)
servo_X_min_momentary (close while pressed)
where X is either 1 or 3
Did you try using your controller bumper buttons to control the gripper like BR did?
Regards,
TCIII AVD
@tciii,
Yellow wire: ok
Buttons prameters: ok
I used buttons 9 and 10 on Logitech
Which are the bumper buttons?
nmau
I have just installed the gripper as well per instructions and got it to work twice before it stopped working. Didn’t get a chance to reboot the rov n software to see if it would start functoning again. Will try again today. Qgc is 3.2.4 rev 6
@nmau,
Link to Xbox controller buttons
Regards,
TCIII AVD
@tciii That link seems to be broken.
In my case, i got it to work but then it stopped. Same buttons, n no changes in between.
Hi guys, sorry you’re having some issues here.
First, I’d like to verify you have the most up-to-date firmware loaded: ArduSub 3.5.3.
Make sure that your button presses correlate to the correct action you want.
After that, please check that you are using the “servo_X_min/max_momentary” and not the other servo settings (min/max or min/max_toggle).
Please post a screenshot of your button settings if possible.
@kaosrulz,
Fixed.
Regards,
TCIII AVD
Everything is working fine now, after the ArduSub update. Thank you @kklemens
nmau
yep it took ardusub update to get it going
Thanks guys, you have turned my inspection class rov into a work class rov by fitting the Newton Gripper. Strong grip on it,so don’t be putting your fingers in to try it out.
@kaosrulz,
I have already put my finger in it!
nmau
Did you have to cut the head off the gripper to free yourself?
@SpatialGuy,
not exactly, but it is surprisingly a strong gripper…
nmau
