Hi im getting 42 degree celcius in my internal temp. But its not in my bottle and its Cold in Norway, but we dont have it this hot at home;)…anyone?
The autopilot pcb is indeed 42 degrees C. The temperature sensor is embedded in the electronics, and the CPU on the auotpilot heats the pcb considerably.
Ok🙈… Else i saw the problem that i Ask in my mail😂… was light from outside i couldnt seee… Low light is Goood;)…you can just delete this post then🤪
