So I’ve run my first mission in the blueboat in less than ideal conditions (20kn winds) and it exceeded my expectations! We’re trying to export the flight logs from the boat (qgroundcontrol froze and had to be restarted halfway, so the qgroundcontrol logs are split), and running into an issue trying to export the data in a useable format.
All we want is timestamps of actual time as well as GPS locations, but using the Log Viewer (UAV Log Viewer) we can’t seem to get the actual time. If we export GPS data from there into a csv we’re getting nonsensical ‘true’ time in binary format (saying year 4025). This is confusing to us because the logs seem to have recorded the correct time where they were saved. Log Viewer also gives a different strange time, saying it’s 2015 for some reason. Is there a different conversion we need to use other than the normal one?
Note this could somehow be due to some errors in the .lua resulting in incorrect LED blinking format that we’re also trying to diagnose.
