hi
how to connect two devices like iPad and laptop to one qgc at same time i try this but at a time on is get connected other get disconnected .
It’s possible to add multiple outputs in companion, go to http:192.168.2.2:2770/mavproxy and add a new output as a new line.
--out udpbcast:192.168.2.255:second_port
Remember to configure QGC to use this new port.
hi
error message come Cannot GET /mavproxy is showing .
thanks @patrickelectric
Please update your companion, check the instructions here.
After the update, you should be able to access /mavproxy.
hi
how to configure QGC to use this new port .
Open QGC, top right Q → Comm Links → Add:
- Add a name, select UDP type, in listening ports add the same port that you are using in mavproxy and for target host use: 0.0.0.0 or 127.0.0.1 (localhost).
Hi, I am also trying to use both PC and tablet at the same time.
I want to control and to watch video stream from the Bluerov2 on my PC and only watch the video stream on my tablet. Is that possible?
Cheers, Jan Robert Fiksdal
Hi Jan,
To capture video stream in multiple devices and QGC at same time, it’s necessary to modify the gstreamer options, changing ! udpsink host=192.168.2.1 port=5600 to ! multiudpsink clients=192.168.2.1:5600,next_ip:port, where next_ip is the second device ip and port the port that you want to receive this video stream.
Hi Patrick,
I made it. Thank you so much!
Cheers, Jan Robert
hi
how you do with wireless setup can you guide me from the starting .
@pob747
thanks
@rohit Check Redirecting...
