I have a FOG Gyro that I need to interface to the Navigator flight controller .
The output from the FOG gyro is multiple ( serial RS232 - NMEA 0183 , ASCII , BINARY ) and
Ethernet UDP unicast , multicast and broadcast , TCP client , TCP Server) .
Is there any ways to feed the gyro output to the Navigator input ?
Please contact me if someone can support with the integration ( i.e. writing code , etc ) I am willing to pay for the support .
Hi @DavideROV -
It may be possible to integrate the FOG gyro - are you trying to interface it with ArduSub? What is your application - what kind of vehicle are you developing?
to adapt the gyro output to something ArduPilot can use…
This isn’t a complete solution, but there is some relevant discussion in this thread, which could serve as a starting point if you’re interested in integration with ArduPilot autopilot functionality
Curious if there is already an solution to receive on the Navigator Board an NMEA string, indeed something like the HDT to override the internal compass in the blueboat!
This option would be amazing to make the BlueBoat/ROV a robust platform with RTK heading from two GNSS antennes / INS headingANDpositioning. The internal compass give so much erros nearby a lot of ferrous surveys areas etc.
Any NMEA position stream can be parsed by the Navigator Autopilot. To receive the messages from a network-connected device simply configure the Autopilot parameters GPS_Type to NMEA, Serial2_Protocol to GPS, and verify no other Serial port # protocol is set to GPS. Finally, under Autopilot Firmware, Serial port Configuration, set Serial 2 to: udpin:0.0.0.0:27000. Then direct your UDP NMEA stream to the IP address of the BlueBoat. Note that these NMEA messages are required for navigation: RMC, GGA, VTG, HDT. This approach uses the ArduPilot driver to interpret the NMEA messages - you can also use the NMEA Injector in BlueOS, which has support for fewer messages. If using a serial connection to bring the NMEA position data to the Navigator serial port 3 or 4, set the appropriate Serial# Protocol parameter to GPS and restart the autopilot. NMEA messages should be sent at 10hz or faster.
I changed the following autopilot parameters:
Serial2_protocol from Mavlink2 to GPS (serial1 was also set to Mavlink2 and unused in Serial port Configuration, no other Serial protocol is set to GPS )
GPS_type from auto to Nmea
Serial5_protocol from GPS to none
Ekf3_src1_yaw from Compass to GPS
Autopilot Firmware:
Serial port Configuration, set Serial 2 to: udpin:0.0.0.0:27000 (also tested udpin:192.168.2.2:27000)
GNSS:
In our Septentrio GPS, made an output to 192.168.2.2:27000, with RMC, GGA, VTG, HDT.
The Cockpit is still outputting an alarm: EK3F is waiting for GPS config data and no position data is showed in the Cockpit when clicking on the Boat.
Further, after save and reboot, udpin:0.0.0.0:27000 is still there, and after a second reboot for example, the line ‘udpin:0.0.0.0:27000’ is removed.
Hi @Willem -
Can you share what version of BlueOS you’re using? This is on a BlueBoat?
After setting serial port configuration, do you save and restart the autopilot via the button at the bottom of the page?
What is the IP address of the Septentrio GPS, and how is it connected to the system? Via ethernet switch?
It may be worth trying the NMEA injector instead of the autopilot serial 2 approach…
I will try this as well, one additional question though. will i still be able to use a fallback of the boats gps and compass if there is no input from the external GPS?
I have the input working, however 2 questions still remain.
1: The instructions clearly state “verify no other Serial port # protocol is set to GPS” Serial5 however (which i would like as a backup) was set to GPS. So i changed it to MAVLink (is this correct?
2: It when i restart the boat, sometimes i get the message EKF3 waiting for GPS config data. in that case autopilot (or hold/loiter) no longer works. only a reboot trough BluOS solves this (temporary)
3: The CPU % of the ardupilot_navig is 34.2 (orange)
Hi @RobB -
How many GPS units have you connected? If the total is 3, you will want to disable Serial5 GPS. Setting it to MAVLink is not correct. With RTK GPS systems, if one GPS loses lock you will still have position.
That error is normal if your GPS don’t have an RTK fixed or floating lock yet. Restarting BlueOS is not necessary - you should be able to eliminate the message by getting a better lock, or restarting just the autopilot process (not the entire system.)
i have one external input set up. the rest is the standard config (factory) i was (apparently) mislead by the instruction “verify no other Serial port # protocol is set to GPS”
Following up on RobB.
We have configured our external GNSS in the autopilot as follows: SERIAL2_PROTOCOL set to GPS.
Only SERIAL2_PROTOCOL and SERIAL5_PROTOCOL are set to GPS GPS_TYPE set to NMEA. Serial 2 set to “udpin:0.0.0.0:27000”.
BlueOS version 1.4.1
Output from external GNSS to serial 2:
Protocol: UDP
IP address: 192.168.2.2
Port: 27000
Messages: NMEA GGA, VTG, HDT, RMC
Frequency: 10 Hz
When I restart the boat, the autopilot (or hold/loiter) doesn’t work. Only a restart of the autopilot through BlueOS solves this. After restarting the boat again, the autopilot again doesn’t work.
In our aquisition software (Hydromagic) I get the following messages from the autopilot: flight mode change failed. Also see picture.
Hi @tony-white,
after POWER OFF the BlueBoat via BlueOS, and restarting manually with the power switch on the boat, the autopilot now continues to function normally. Whereas before after restarting the boat, the autopilot didn’t work. Now after every restart of the boat, it works good.
I don’t know why, but a power off via BlueOS seems to have solved the issue? Do you have an explanation?
Hi @tony-white,
The issue returned. Also after restarting the boat via BlueOS, the auto pilot doesn’t work. Only after resetting the auto pilot it’s starting to work again.
Anything you can help with?
Regards, Otto
Hi @OttoGeometius -
We received your email in reference to this thread - answering here, apologies for the delay.
It is quite ambiguous what problems you’re facing - had things been working without issue for the past month before this issue surfaced again? Did anything change, in terms of software updates or with the vehicle hardware?
Sharing BlueOS system logs, from the gear icon in the lower left of BlueOS, may shed light on your situation. Generally, it sounds like your RTK GPS system isn’t always sending information when the autopilot is ready for it, or the data it is sending isn’t valid for some period during start-up. Unless connection to the GPS is lost abruptly during operation, the system seems to be operating within nominal expectations…
