Hi everyone,
I’m working on a custom tether spool and I’m having trouble getting a stable Ethernet connection through my slip ring.
The Problem:
When I connect my devices directly with the Ethernet tether (bypassing the spool and slip ring entirely), I get a perfect connection.
When I connect through the spool and slip ring, I get no connection at all (no link lights).
Troubleshooting Steps I’ve Taken
I did a few tests to isolate the problem, and I’ve narrowed it down. It seems my individual components are working, but they fail when used together.
Here’s what I found:
Test 1: Long Tether Only I bypassed the slip ring completely and connected my long tether directly.
Result: I got a perfect, stable connection.
This proves: The long tether cable and its connectors are wired correctly and are working fine on their own.
Test 2: Slip Ring Only I tested the slip ring by itself using two short, known-good Ethernet patch cables.
Result: This also worked perfectly.
This proves: The slip ring and its Binder connectors are wired correctly and the slip ring is functional.
Test 3: The Full System I reconnected the complete system as intended (Long Tether + Slip Ring).
- Result: The connection failed immediately.
Given that my connection only fails when combining the long tether with the slip ring, what are the most effective ways to fix this signal integrity issue?
