ERRO WHEN EXECUTING GPS AIDED NAVIGATION USING MAVROS
Hai,
I am trying to do GPS-aided navigation using MAVROS for my ASV(2-thruster configuration). I am using my computer as the ROS master and a Pixhawk 6C. The code shown below pushes the waypoints to the FCU and then switches the FCU to ‘AUTO’ mode. But after pushing the waypoints I am getting the following error:
WARN] [1686162708.172762253]: CMD: Unexpected command 11, result 0. I am using ArduRover V4.2.3
This is the code I am using for GPS navigation using MAVROS:
#!/usr/bin/env python
import rospy
import mavros
import sensor_msgs
import yaml
from mavros_msgs.msg import *
from mavros_msgs.srv import *
from std_msgs.msg import String
from sensor_msgs.msg import NavSatFix
latitude = 0.0
longitude = 0.0
altitude = 0.0
last_waypoint = False
flight_altitude = 3 # Check altitude value before experiments
def waiter(condition):
while True:
if condition:
return
else:
rospy.sleep(2)
def waypoint_callback(data):
# print(“\n----------waypoint_callback----------”)
global last_waypoint
# rospy.loginfo(“Got waypoint: %s”, data)
if len(data.waypoints) != 0: # If waypoint list is not empty
rospy.loginfo(“is_current: %s”, data.waypoints[len(data.waypoints)-1].is_current)
last_waypoint = data.waypoints[len(data.waypoints)-1].is_current # Checks status of “is_current” for last waypoint
def globalPosition_callback(data):
# print(“\n----------globalPosition_callback----------”)
global latitude
global longitude
global altitude
latitude = data.latitude
longitude = data.longitude
altitude = data.altitude
def clear_pull():
print(“\n----------clear_pull----------”)
# Clearing waypoints
rospy.wait_for_service(“/mavros/mission/clear”)
waypoint_clear = rospy.ServiceProxy(“/mavros/mission/clear”, WaypointClear)
resp = waypoint_clear()
rospy.sleep(5)
# Call waypoints_pull
rospy.wait_for_service(“/mavros/mission/pull”)
waypoint_pull = rospy.ServiceProxy(“/mavros/mission/pull”, WaypointPull)
resp = waypoint_pull()
rospy.sleep(5)
return
def finishWaypoints():
print(“\n----------finishwaypoints----------”)
while True: # Waits for last_waypoint in previous WaypointList to be visited
rospy.sleep(2)
# Waiting for last_waypoint to be true
if last_waypoint == True: # If last_waypoint is in the process of being visited
while True:
rospy.sleep(2)
# Waiting for last_waypoint to be false
if last_waypoint == True: # If last_waypoint has been visited (due to previous constraint)
break
break
return
def armingCall():
print(“\n----------armingCall----------”)
rospy.wait_for_service(“/mavros/cmd/arming”)
asv_arm = rospy.ServiceProxy(“/mavros/cmd/arming”, CommandBool)
resp = asv_arm(True)
rospy.sleep(2)
def pushingWaypoints(poi):
print(“\n----------pushingWaypoints----------”)
rospy.wait_for_service(“/mavros/mission/push”)
waypoint_push = rospy.ServiceProxy(“/mavros/mission/push”, WaypointPush)
resp = waypoint_push(0, poi)
rospy.sleep(5)
return
def switch_modes(): # current_mode: int, next_mode: str ([mavros_msgs/SetMode Documentation](http://docs.ros.org/jade/api/mavros_msgs/html/srv/SetMode.html))
print(“\n----------switch_modes----------”)
rospy.wait_for_service(“/mavros/set_mode”)
modes = rospy.ServiceProxy(“/mavros/set_mode”, SetMode)
resp = modes(custom_mode =‘AUTO’)
rospy.sleep(5)
return
def disarmingCall():
print(“\n----------disarmingCall----------”)
resp = asv_arm(False)
rospy.sleep(2)
def main():
rospy.init_node(‘gps_navigation_node’, anonymous=True)
rospy.Subscriber(“/mavros/mission/waypoints”, WaypointList, waypoint_callback)
rospy.Subscriber(“/mavros/global_position/raw/fix”, NavSatFix, globalPosition_callback)
#readyBit = rospy.Publisher(“/mavros/ugv/ready”, String, queue_size=10) # Flag topic
clear_pull()
armingCall()
waypoints = [
	Waypoint(frame = 3, command = 16, is_current = 0, autocontinue = True, param1 = 5, x_lat = 38.99044, y_long = -76.93776, z_alt = 0),
	Waypoint(frame = 3, command = 16, is_current = 0, autocontinue = True, param1 = 5, x_lat = 38.99066, y_long = -76.93738, z_alt = 0),
	Waypoint(frame = 3, command = 16, is_current = 0, autocontinue = True, param1 = 5, x_lat = 38.99113, y_long = -76.93747, z_alt = 0),
	Waypoint(frame = 3, command = 16, is_current = 0, autocontinue = True, param1 = 5, x_lat = 38.99079, y_long = -76.93777, z_alt = 0),
	Waypoint(frame = 3, command = 16, is_current = 0, autocontinue = True, param1 = 5, x_lat = 38.99056, y_long = -76.93791, z_alt = 0)
pushingWaypoints(waypoints)
switch_modes() #changing from manual mode to auto mode
finishWaypoints()
rospy.sleep(10)
disarmingCall()
print("Mission completed")
rospy.spin()
if **name** == ‘**main**’:
main()
It would be really helpful if someone can solve the issue.
Hi @nvnanil, welcome to the Blue Robotics forum :slight_smile:
We don’t maintain ArduRover (only ArduSub), and generally can’t provide support for firmwares we don’t maintain if they’re not used on our vehicles / equipment. I’d recommend asking in the ArduBoat category of the general ArduPilot forum :slight_smile:
11 is the SET_MODE MAVLink message, which has been deprecated in favour of using MAVLink commands. Perhaps that’s the cause of your issue, in which case it can likely be fixed by using the command protocol equivalent instead of the SetMode message in your switch_modes function.
Thanks @EliotBR .
I will keep in mind when posting the next time.
The issue was solved. If anyone facing the same issue refer to the ArduPilot Forum:
