Enhance Bandwith Fathom-X board with Coax tether
Hi, I have and issue regarding the speed, it is always less than 50 mbps, the best of them (with 125 m tether) about 50 mbps. I did some research to this Ethernet over coax terminology, most of them said “Coax can make the bandwith better and longer distance”
Is that correct and prooven with this board?
Thanks everybody
Hi @iqbalwiawan -
50-80 mbps is the typical maximum speed possible with the Fathom-X two-wire ethernet adapter. Making sure your two wires are the exact same length, and twisted together consistently along the entire length can help improve this! Using a co-ax cable is also possible, but not likely to improve bandwidth above 80mbps, and is also typically more fragile than Fathom tether…
If you need higher speeds, a more modern homeplug adapter could do the trick!
