on further investigation i have been able to verify approx 50-60mb link through the fathomx. I hadn’t realised the gstreamer video was still running when I ran the last test.
so link speed is ok, the symptomatic laggy video is a different topic!
we’re using the 200m reel from BR.
i reran the iperf test with all video streaming stopped &achieved the 50-60mb. i can live with that speed, but am struggling to get the video feed to be acceptable.
the low light HD camera works a treat with a direct connection, but through the fathom &200m reel, it stutters and updates every 5secs or so.
the original iperf data was with video streaming running.
Okay, that sounds like a normal speed for 200m length. Can you try with a shorter length of wire between the Fathom-X boards? If that fixes it then the tether length is likely the issue. If not, then there might be something wrong with one of the Fathom-X boards causing packet loss.
thanks for the help so far,
i have done that test, getting similar speeds, I.e. approx 60mbps (using iperf).
used a length about 20cm twisted pair.
should the speed be better than that?
We usually see closer to 80-90 mbps over short cable lengths. That’s assuming the video isn’t running. If you think something is wrong with one of the Fathom-X boards, send us an email at support@bluerobotics.com and we can sort it out.
