Elgato facecam in BlueOS
Hi, we have a Blueboat USV and would like to use a Elgato facecam to the RPI inside.
When we connect the camera to one of the USB 3 ports it shows as detected in the BlueOS video section but the video feed doesn’t work.
Is there a way to solve this?
Cheers from Norway
Hi @pob747 -
That looks like a cool camera! However it does not list Linux as a supported OS, or seem to have a UVC driver. It also seems to default to MJPEG instead of H264. If you’re able to configure it for 1080p H264 stream when connected to another computer, it may work with BlueOS and the Raspberry Pi 4, but I’m not optimistic that it will be fully compatible.
For about the same price, this waterproof camera does work - but is only 1080p…
Thanks for the information.
I will try to set it up as suggested.
Cheers :slightly_smiling_face:
