Great any information would be great. Hoping to place an order soon. Also can we get a single lumen on a 100m wire since you can purchase the lumen wire by the M?
Regards Dustin.
Regards Dustin.
See my response above the picture.
So I am guessing it fits? So I should be good to order those parts and figure out some other lighting?
Yep, it fits with a couple millimeters to spare in the 2" tube! I donât know of anyone who has made an electronics tray that small, so you are a bit in uncharted territory.
Sounds great I will figure something out. Just double checking So with the analog camera with the s board doesnât require a power source?
The Fathom-S will require a 7-20V DC power source. I donât really have any suggestions for anything with that voltage and is small enough to fit in a 2" tube with the board.
Ok will look into it. And for that. What amperage?
Airsoft battery from HobbyKing might work perfect.
