Depth of field of the Low-Light HD USB Camera
Is the depth of field of the Low-Light HD USB Camera when mounted in the standard electronics enclosure known?
Do you mean the Raspberry Pi low-light HD camera?
Thanks Darrell. I’m referring to Blue Robotic’s Low-Light USB camera It seems to have different specifications to the Raspberry Pi cameras - eg Blue Robotics camera is:
Field of View (Horizontal) 80°
Field of View (Vertical) 64°
Focal Length 2.97 mm
Raspberry Pi cameras are;
Focal length 3.60 mm +/- 0.01 3.04 mm
Horizontal field of view 53.50 +/- 0.13 degrees 62.2 degrees
Vertical field of view 41.41 +/- 0.11 degrees 48.8 degrees
A depth a of field value is not available from our supplier.
