I have some thrusters that ere controlled via a serial RS485 connection and looking where in the code to insert the serial control code instead of using the PWM outputs for the ESC controllers.
I am building with BlueOS and the new navigator board which has the additional UART ports for the serial control that I am hoping I can use for this.
Is there somewhere I can read up on the workings of the Ardusub source code and how everything is put together and the process loop etc?
