Quant je ping depuis mon ordinateur portable sur le réseau du bluerov, la réponse que j’obtiens est impossible de joindre l’hôte de destination,
J’ai besoin de savoir le schéma de branchement des câbles au niveau du Fathom-X FXTI
Check your firewall setting’s, also fathom-x wiring diagram is on setup page, hope this helps
Hi @echbelmohamed,
I just covered the wiring in another thread here:
If you’re having network issues make sure you’ve followed our Software Setup Guide. Once you’ve selected your operating system there will be relevant network setup information (e.g. here is the network setup section for Windows). Part of that includes allowing QGroundControl through your firewall, as @murf mentioned ![]()
